known12345
- Nov 17, 2007
Was wondering, how exactly do you know when you reached the limits of the overclocking potential of your chip, ignoring cooling for now?
I mean how do you know that your chip cant keep going forward as opposed to you having insufficient cooling?
With a q6600 I was able to get to 3.6 at 1.496v to run on prime95 for 10 hours (Antec P182 fans high, ABIT IP35-E, Arctic Freezer 7 Pro, side panels off, roommate's desk fan at high) but not without seeing a high core temp of 65-70C (average of about 68C) and a high PWM temp of 85-100C (average of about 93C). Obviously it would be very foolish of me to leave my settings the way they are as I am extremely stressing my parts (and the fact that the settings are completely overkill) but it made me wonder if I would possibly hit 3.7. More importantly, I wanted to know how high could my chip go AND successfully complete prime95 for 10 hours.
Obviously the higher I attempt to overclock the card, the more cooling I will need to ensure the card doesn't take damage but lets just say cooling wasn't an issue (for now). I know the inability of my FSB setting to POST is an obvious sign that the card has reached its limits but are there other signs that signify I am getting close to my limit?
I set my FSB to 420 and 1.54something v and I was unable to POST. After resetting my BIOS (boy was I terrified for a second), I set the FSB to 405 and 1.5075v and I successfully POST and started up windows and confirmed I had a FSB of 405. At 4am in the morning and feeling very tired, I decided against running prime95 (for now) as I knew the temps were going to be extremely high and I would have to find some creative way to cool the comp which would be easier if I had some rest. Instead I wondered if my cpu would POST at higher FSB so I set it to 410 and 1.5075v and was able to go to windows and check CPU-Z to verify the new FSB. Then I went to 415 and 1.5075v and it again I was able to go to CPU-Z and verify the new FSB. Finally I jumped to 425 and 1.5075v and I was able to get to windows and check CPU-Z but this time the computer felt EXTREMELY laggy as if I was running too many programs at the same time. It took a long time to open CPU-Z, the ABIT BIOS program, Core Temp and various other computer checking programs. At that point I wondered if I had hit the very limit of my CPU.
On a side note, is there a particular reason why I was able to POST at 425 at 1.5075v and not at 420 at 1.54something v? Ive read about situations where sometimes someone is unable to POST at a particular FSB (or range of FSB) and simply passing the number or range (if there is a number or range; they could have possibly hit their limit) may allow them to try their card at higher temperatures.
Anyway, back on topic; when the computer shows extreme lag in an overclock, does it signify that the limits of overclocking has been reached or on the verge of being reached? If that is the case, should I even attempt to try to run prime95 at 425 or just simply attempt to run prime95 at 415 (or possibly 420) and call it a day whether or not I am able to run with no errors for 10 hours? Ofcourse I will try my very best to ensure adequate cooling is available and sufficient vcore is provided but I suspect 3.6 was by far the limit for my card and nothing short of getting a better PWM cooling motherboard, a better cpu cooler, or possibly a water cooling system would alleviate the heat coming from my cpu/motherboard.
Also quick question, ive heard of people having motherboard failures and having to replace them... is overclocking the reason why their motherboard failed?
