OK, i have an opteron 165 oem from newegg that is a ccbwe 0530 stepping(supposed to be good) on a chaintech vnf4/ultra mobo with 2x512mb corsair xms pro. The proc is watercooled by a swiftech 6002 and dual 120mm heatercore setup. Right now I am running 9x278 with a 133mhz divider on the ram to keep it out of the equation for now, so it is at 178mhz. This is all on 1.45 volts, my idle temps are 32 deg C and highest load i've seen is 35C(yes these are cpu and not mobo temps, case temp is 19C right now, its cold damnit!). I have an evga 7800gt n16 model with the copper cooler on it that is being kept at stock clocks right now for testing the cpu out. The problem is whenever I take the cpu higher, I can boot into windows and do whatever up to 2.7 ghz without a sweat but whenever I run any 3d apps it artifacts right away. Is the pcie bus being unlocked somehow or do I need more chipset voltage?? This seems strange to me, all temps are great and I have put up to 1.55v on the opteron. Thanks.
