ok...this seems like a rather easy question...but I just wanted to check anyway.
Every once in a while, 4-5 hours so far, the computer will just lock up. Everything freezes, it can be while on aim, while listening to music, while browsing, etc. So I doubt it's because I'm stressing it (unless F@H is stressing). The mouse freezes, cap locks doesn't light up, but the optical drives and stuff still work. I can't hear the hard drive powering down or anything so I'm pretty sure it's not that. Temperatures don't change (according to the physical diode they don't anyway) and are still safe (chills a couple °C above 40 with F@H, AIM, and Firefox)
Sooo...yeah...I was thinking this would probably be something to do with voltages or timings correct? Not actual hardware? or could it be either?
Not sure if system specs are really relevant..but..
3.0C @ 3.6 vcore is at 1.6 (rather high I think, but the vcore fluctuation makes it 1.56 most of the time)
IC7-G BIOS 28
G.Skill 1 gig (2×512) PC4400 LD (freaking piece of crap, lesson to you all, do not buy stuff at one in the morning "hmm..g.skill...ah there it is..well there's two...ahhh too much text I go for that one" *click* *several days later* "finally!!! .......ohh..........crap" -_-)
Thermaltake Purepower 420 watts ( thermaltake!)
IC7-G BIOS 28
