Oct 13, 2008 #1 M mito Gawd Joined Mar 27, 2006 Messages 598 Can I overclock more the already oc'd 280 gtx ftw. Or has it reached it's limit at factory 670MHz? ---> EVGA GTX 280 Ftw 670MHZ
Oct 13, 2008 #2 T TekRok 2[H]4U Joined Dec 9, 2005 Messages 2,279 sure why not, as long there are no artifacts you are good to go
Oct 13, 2008 #3 M mito Gawd Joined Mar 27, 2006 Messages 598 does the evga 280 gtx ftw (670 Mhz stock) have better components to reach even higher frequencies? For example: 670Mhz + 10% = 740Mhz... It's quite a difference from nvidia's stock 602Mhz specs, right?
Oct 13, 2008 #4 Suprfire 2[H]4U Joined Sep 1, 2008 Messages 2,116 Pump up the mhz, then do a stress test, and take a look. Doesn't hurt to try.
Oct 13, 2008 #5 Crosshairs Administrator Staff member Joined Feb 3, 2004 Messages 25,335 My Volt modded 260 runs 729Mhz Core, 1458Mhz Shader and 1216Mhz Memory..so I would say you should still have room in that card...
