Chowder Head
- Oct 20, 2005
Hey guys, I bought and put together my rig a few weeks and now I'm ready to get into it and start overclocking. I had oc'ing in mind when I was selecting my parts (see sig) and now it's time to see what my setup will really do.
My rambling aside, my first question would be should I overclock a specific part first such as the RAM, cpu, etc, or what I start off at won't really matter?
Next up, I'm sure you guys read eclispses RAM guide, so hopefully someone can answer this question. Here's an exert from his guide:
"Ok, for the testing, I like to do something like this: Find lowest timings possible at whatever the stock speed of your motherboard is. Say that I have some pc4400 (275mhz) and put it into a Athlon64 rig, the memory will automatically run at 200mhz. Find the tightest timings at these speeds.
Next, raise the timings one at a time until you find the one that makes the largest mhz increase over your previous timings, and find the max. repeat until you get to 3-4-4 timings."
Now the specs for the stock timing for the G.skill RAM I have are already 3-4-4-8. So should I skip this step and begin to lower Tcl and so on?
And my last question for right now, is when I start overclocking and want to test for stability, I can load memtest on a CD and have that accessed before my OS loads, correct?
Any help is greatly appreciated, thanks guys!
