PnoT said:I'm running 1.7v atm and it's stable but i'm kinda worried i might have gone too far. All these ppl talking about northy's taking a plunge over 1.65 heh.
RM_Bulldog said:the C P4s still have some issue with voltage
Glyphic said:I ran my 3.0c at 1.7 for a while, but I turned it back down since I'm still on air, once I get my water I'll see how far I can push it....
lithium726 said:what an amazing underclock!
TekViper said:those early northwood chips were great overclockers. This 2.8 prescott i have now is a turd tho
diredesire said:I got mine up to 2600 with no AGP/PCI lock on a P4S533
I loved that chip, too. Just had a crappy FSB.
My first one wouldn't even do 2400 reliably (100 -> 133), i traded with a friend who doesn't overclock and his chip was great ;D
Nexx said:I have a 1.8 C stepping out of a Compaq computer that will oc into the 3.2GHz range
cornelious0_0 said:Good ol' Compaq's eh?
Got any CPU-Z shots of it or any scores?
Nexx said:I really havent bothered with benchmarking that system. Its been running my file server for awhile, running on an Asus P4P800. I recently upgraded it to a Dual Xeon 1.6 running at 2.4ghz each. I got the cpu for free from a guy who upgraded his compaq. i was amazed when it would run 100% stable at 2.4ghz @ default voltage. I started cranking her up and ended up at 1.65 volts at 3.2GHz with great stability. I did run cpuz on it once just to verify it was a C stepping like I suspected. Now that I think about it. a 1.4GHz overclock is pretty amazing LOL.
v3rt1g0 said:OMFG to the two guys that actually corrected this guy's JOKE!
you KNOW what a means, RIGHT?
PnoT said:I'm also wondering if i should run my memory at the 1:1 i have it at now or 3:4 to get it up higher. From what i've read 1:1 is better correct?
Nitro16 said:If you can, run the divider at 3:4, that will put your memory at DDR400 levels and should improve performance (considerably if your board is single channel).
cornelious0_0 said:You still got the CPU? got any old pics of the CPU-Z? It's not that I don't believe you.....far from it.....I just wanna see that 1.4GHz OC in pic form....looks so much nicer.
Nexx said:I might just have to install it and fire her back up one more time for this. I'll see what I can do.
