I have the P4 640 3.2 Ghz processor. In my Asus bios, I go to overclocking, select 20% A.i. Boost, and restart. Now the clock speed is 3.84 Ghz. When my voltage is stock, 1.3875, I get pretty decent 3dmark06 scores (like 3975). When I set the vcore voltage to 'auto', I noticed it's around 1.45 --> 1.5, somewhere in there.. anyway, my score drops drastically, like 300 points.
Is there a recommendation you guys can make on the voltage? I mean, doesnt overclocking 20% mean I should put 20% more voltage? Or should I just leave it at stock and things should be fine? I dont want to be hurting the processor by either giving it too much voltage, or not enough. I want my performance to be optimal with this overclock.
Also I left DRAM voltage at auto and ram timings on auto. When I started fiddling with those timings things started getting weird.
FSB is at 960 (quad pumped, so 240 mhz), ram is 698mhz (DDR2)
