hi, recently i've noticed that my mobe temps are higher than they usually are. usually they are high 30s-40; now, they are in the low to mid 40s. i've just recently removed the plastic off the north and southbridge heatsinks as well as the ez-raid thing...that didn't seem to help motherboard temps at all. infact. it seems as if temps rose about 1-2 degrees, however, it also seems as if my cpu temps have dropped a few degrees which i found quite odd. i am currently idling at 44C on the mobo temp (as reported using both Asus ProbeII as well as everest). btw, room temp is about 22C and vCore is auto w/ stock HS on a E6600 at stock speeds. so, i am wondering if the temps i am experiencing are anything to worry about, and if they are, what can i do to lower the temps?
Thanks in advance for any helpful advice
