Version 1504 2009/05/04 update
OS DOS / All OS
Description P6T Deluxe 1504 BIOS
1. Fixed the key may lag in BIOS setup when a Turbo Mode ratio was selected.
2. Supported EIST function when CPU ratio is in manual mode.
3. Adjusted max value of CPU ratio setting according to the number of cores active in BIOS setup.
4. Fixed setup item "CPU Ratio Setting" may disappear if down CPU ratio.
5. Fixed Vista may loading slowly when populated memory size is larger than 3GB and with high-end VGAs.
OS DOS / All OS
