I am having the same issue. I have version 1.01.14 of the AI Suite, which is the latest on ASUS' site. I had CPU-Z, OpenHardwareMonitor, and RealTemp running the first time I got the warning. Before the -60 C warning, I also got a few warnings about the 12v power but they disappeared before I could read the exact warning.
The temperature reading problem is because more than one piece of software is accessing the Super I/O, causing it to feedback incorrect readings
Avoid running AiSuite II with any of the following utilities:
- CPUz
- Everest
- SpeedFan
-ITXU
- basically anything that probes the Super IO at the same time as AI Suite.
I too would like to know this.Thanks for the explanation. I used AI Suite to bump up the multiplier. Once I have done that, do I still need to keep AI Suite running to maintain the overclock? Do I need to run it at all if I am not changing settings?
I find it strange that I can have CPUz, RealTemp, and OpenHardwareMonitor all running at once without noticing any problems. *shrug*
