Thanatos.
- Jun 24, 2005
So im getting ready to setup a computer for my mom (still running a P3 900Mhz) and old AMD Athlon XP 2800 setup (got it for free from a friend) and the case has seen better days its a silver/grey setup and i wanted to paint it black (possibly white but that might show too much). Ive got some Vinyl Dye for the front face and have the case disassembled but heres where i hit a slight snag ive read alot on painting today (like Arcygenicals awesome guide) and most go into way too much work for a somewhat antiquated computer for my mom. Im not going to clear coat it and i dont care if its flat black or glossy i just want the case to be black (outside only no inside painting) and not chip so can i just do some light sanding and put a thick coat of black primer on the sucker and call it good? If so do i need this Self Etching primer or some other type? What would the disadvantages be for using just primer? Also can i vinyl dye the acrylic window (mom doesn't need a window)? You input would be greatly appreciated as i hope to finish this project by the weekend.
