I'll be painting my Inspiron 9300, but only the top bit of it... hard to describe but the bottom is a nice black I do enjoy and the keyboard colour is just fine at black also.
I'm looking for suggestions and advice on how to do this, I found instructions on removing the parts I want to on Dell's website so I can sand and paint just the parts of which I want to re-colour.
Here is a picture of an Inspiron 9300-
I want to paint the edges of the screen and the silver/white around the keyboard. Also the closing upper part of the lid and if anyone has suggestions replace the Dell logo with "Lsv"
Here is an imagine of the top lid-
Thank you in advanced.
PS - I've started sanding down the top lid with 320 grit sanding paper and moving up to 400 -600 and 800. Should I go higher than 800 before washing/drying and applying the first layer of paint?
