I'm in the process of buying the all products I need to paint my PC case.
My Case:
http://www.hardforum.com/showpost.php?p=1030646506&postcount=20
My Motivation:
http://hardforum.com/showpost.php?p=1030686058&postcount=11
I will most likely following this guide:
http://case-mods.linear1.org/case-mod-101-how-to-paint-your-computer-case-part-1/1/
I know what to buy and I've painted before using Spray Paint...But I need to get perfection for all of this, Questions:
1. My Case has Metal for body, and plastic as the front. Can I use the same Primer, Paint and Clearcoat for both plastic and metal?
2. I will also be painting inside my case, will I need to do a perfect job of Wet and Dry Sandpapering inside my case? As it looks a lot harder than sanding the panels, top, bottom etc.
Have any tips? Tricks? Suggestions?
Cheers.
My Case:
My Motivation:
Cheers.
