I'm about to swap out my old case for a new Coolermaster Centurion 5. I'm debating between an SI-120 and an XP-90 heatsink, and planning to swap out all of the fans in the case for better cooling and less noise.
I'm going to replace the front 80mm with Panaflo 80mm L1BX
I'm going to replace the rear 120mm with Nexus 120mm Fan
If I get an XP-90 I'll put a Panaflo 92mm L1B on it.
I'm not sure whether I would go with another Nexus on the SI-120 or a Panaflo.
I'm going to buy everything from Jab-Tech. My rig is in my sig. Should I go for the XP-90 and Panaflo L1B combo, or an SI-120 and some other fan?
Thanks,
Oline61
Thanks,
Oline61
