OK, so this is just a general thread i thought i would start about mouse control in games and the various settings that seem to effect it. What is the ideal setup for perfect mouse control in FPS's?
Like, you have
windows settings, mouse driver settings (like use logitech setpoint instead of windows)
enhance pointer precision
Laser / optical
Acceleration
Mouse Smoothing
angle snapping
Poll rate (1000,125, etc)
144hz, 120hz, 100hz, etc (not even sure why this setting would effect mouse movement)
Mark C fix
cheese fix
CPL fix
different settings for XP, vista, 7, 8.1, and even 10 by default
The resolution you game at apparently changes the feeling, so same settings on 640x480 will feel totally different at 1920x1080.
Some games have settings like reduce mouse lag
Nvidia SLI and ATI crossfire (apparently SLI will totally change the way a mouse responds
G-sync, free sync, ULMB, light boost technology.
Then you have 100 different mices, from laser, to optical, with different settings and sensitivities. Use a razer laser mouse with the same settings as a logitech laser mouse, and the feel is going to be totally different.
So to end my post, my question is, in the last 10-15 years, how have we not perfected mouse control on the PC yet? I feel like it shouldn't be this complicated. You should be able to just sit and play, and not have to adjust and make sure 100 different things are setup perfect for you, and then how do you know your settings are the correct ones, and if you had them setup a different way, maybe your aim would be marginally better?
How does say fatal1ty's aim overshadow say the average FPS gamer by like 400% (fictitious # but 1 persons aim may be on a totally other level in comparison to someone elses, and im getting at could this be due to settings, or is it really a human person difference?
Like, you have
Laser / optical
Acceleration
Mouse Smoothing
angle snapping
Mark C fix
cheese fix
CPL fix
