I have been seeing a lot of pci express 2.0 cards coming out and have been wondering if they work on the 1.1 boards. Also what is the advantage of pci express 2.0 over the other versions they are still x16 rated.
Just don't buy anything like 3870x2 or faster. PCIe1.1 seems to be a bottleneck. It really sucks since I just built a new PC.
Got any links to back that up? I haven't seen anyone talking about being bus-limited...
Agreed, and I may have even read from one of the reviews in effect to the contrary. At this point, I don't think it will make much of a difference.Got any links to back that up? I haven't seen anyone talking about being bus-limited...
Actually, as I'm thinking about this, as long as it is a single card setup it won't matter. The 3870X2 transfers data between GPUs via an onboard bridge chip, not via the PCI-E slot, so the only chance of hitting any sort of bottleneck whatsoever that I can think of would be tri-SLI on a PCI-E 1.1 board...
True but you also got to remember that you are still having to deal with bandwidth consumption of two GPUs. even though they are 1 card the cores are still seperate so they will still consume the same bandwidth as a cross fire setup.
I would like to see someone reputable like {H] test this card on a P35 mobo to see if there is any difference. Everyone is testing them on X38 mobos.
i think p35 is the model of board and x38 is the chipset installed onto it which would be an intel chipset. any way i would say they test this on one of the asus p5e3 boards i have read the review they gave the board and it shows that it has a lot of power behind it and it is PCI-e 2.0 compliant. also it comes in ddr2 and ddr3 models
And any P35 motherboard will only be PCI-E 1.1, and any X38 will be PCI-E 2.0. That's the responsibility of the chipset.
OK, class dismissed, quiz on Wednesday.
so any moltherboard w/ PCI-E before P35 is PCI-E 1.0 correct? which isn't comaptible with 2.0?
but anyone who buys a VIA chipset isn;t looking for performance! haha
PCI-Express 2.0 is NO FASTER AT ALL than 1.1a.
See here: http://www.tomshardware.com/2008/01/23/crossfire_meets_pci_express/
Ok its a little faster.
but 2%? Who'd even notice?
Looks like you need to go back to school to learn some reading comprehension. First, it is PCI-E 1.1, not 1.0. Second, as has already been stated, PCI-E 2.0 is backwards compatible - its a bit like USB 1.1 and 2.0 (just not as drastic of a speed bump).
I was speaking about the motherboards before the P35 clearly. PCI-e 1.1 is fairly new I believe. and the 965P and 975 intel chipsets do not have it i also believe, they have the 1.0a believe. Does anyone have any info on these hardware changes for compatibility, i know the difference between them all, just not what goes with what. I would like to know if i need to buy a new mobo before i but a 9800GT in the future.And any P35 motherboard will only be PCI-E 1.1,
I didn't know myself, so I Googled a bit, and came up with this list of chipsets with their corresponding PCI-E version. It's in Dutch, but you should still be able to decipher the table half-way down just fine.
It looks like pretty much all PCI-E slots that aren't 1.1 or 2.0 are 1.0a; not sure what happened to 1.0 vanilla. Reports from other people on the forum is that the PCI-E 2.0 graphics cards work just fine on nForce4 chipsets, which are most assuredly 1.0a, not 1.1, so most PCI-E 1.0a motherboards should be fine. The exception is VIA chipsets; there have been reports of problems on those!
Grow up. You said this:
Q5: Then PCIe 2.0 must be backward compatible with PCIe 1.1 and 1.0?
A5: Yes. The PCIe Base 2.0 specification supports both the 2.5GT/s and 5GT/s signaling technologies. A device designed to the PCIe Base 2.0 specification may support 2.5GT/s, 5GT/s or both. However, a device designed to operate specifically at 5GT/s must also support 2.5GT/s signaling. The PCIe Base specification covers chip-to-chip topologies on the system board. For I/O extensibility across PCIe connectors, the Card Electromechanical (CEM) and ExpressModule specifications will also need to be updated, but this work will not impact mechanical compatibility of the slots, cards or modules. Currently, the PCI-SIG is defining the PCIe CEM 2.0 specification which has been released to members for review at v0.5. There are currently no plans to adapt the PCIe Mini CEM specification for the faster bit rate as the market need has not yet materialized.
Sweet, hopefully the the 9800GT wont get bogged down by the PCI-E 1.0a bandwidth!
Thanks farfromhome!
