http://www.newegg.com/Product/Product.aspx?Item=N82E16819116285
Here is what he said... (first off, this isn't a 64 bit supported processor. Also on the second comment... It's not even the fastest non ee P4!!
Pros: Price, 64 Bit Support, Fastest Pentium 4 Made, Works Great as a Space Heater
Cons: HEAT!, Expect Idle Temps in the 60's and Load Temps in the 90's That's Celsius
Other Thoughts: Well if your one of the unlucky people stuck with a Intel 915 or 925 Based LGA775 System this is as good as it gets, This is the fastest Non Extreme Pentium 4 that was made, One thing to consider is the heat output of this CPU This chip will Idle around 65C and Load Temps could hit 90C!! This is NOT a Chip to use in a Small Form Factor System or a Computer without Plenty of Cooling
and... (CPU WITH NO PINS!!!) LoL. Probably thought the 775 was a 478.
Pros: none, couldn't mount this CPU as there are no pins on the back of it!
Cons: might have worked if it was assembled properly. It's like it missed a step on the assemble line, no pins on the CPU. Kind of hard to install it with no pins on it. I can solder but I'm not that good, haha.
Other Thoughts: I sent it back today with the RMA and I will see how long a new one takes to get here and see if it has the pins on it.
