I was just curious if the performance benefit between a 2 and 3 120mm fan radiator is close to linear or if there were certain characteristics between these to make note of. For instance, if the fans are low rpm is there a significant difference in performance between them? I'm just playing with the idea now, so I don't have any details of what the rest of the system might contain. Tubing would most likely be 1/2
thanks in advance
thanks in advance
