Greetings all. BFG 7800GTX user that decided after 2+ years it was time to reimage his primary PC. So I took it outside, blew out all the parts with canned air, removed the old video card and hard drive (250GB Seagate SATA), replaced them with the new parts (PNY 8800GTX and a 500GB SATA drive), hooked it back up at the desk and installed Vista.
I actually did some downloading, installed the drivers, and had started Windows Update before going to bed. A while later, I heard this whine that I believe was an alarm on the video card. I guess if power is an issue with the 8800GTX, an alarm will sound? In any event, I didn't even see where my downloads were at. I simply held the power button and stopped the noise, then went back to bed.
This morning, I'm trying to put my arms around the situation. Obviously my computer specs will be necessary for those inclined to help...
DFI LANPARTY UT nF4 SLI-DR 939 NVIDIA nForce4 SLI ATX AMD Motherboard - Retail
AMD Athlon 64 X2 4400+ Toledo 2.2GHz Socket 939 Processor Model ADA4400CDBOX - Retail (using stock heatsink and fan)
2x1GB Crucial PC3200 DDR Memory
PNY Verto GeForce 8800 GTX - VCG8800XXPB
Corsair HX Series CMPSU-620HX 620W Power Supply
NEC 16X DVD±R DVD Burner Silver IDE Model ND-3540A - OEM
Apple G5 Case modded with Aluminum Motherboard Tray and JB Welded Drive Bays
The only real quirk to my PC is given the G5 case, I had to mount the PS vertically, with the power connector facing down. Essentially the airflow was backwards at this point, so I opened the power supply and inverted the fans. This allows cool air to be sucked into the case from below, and that air is forced out of the power supply and blown out the front of the case. Though I've gone through a PS already, as the original Enermax 600w I purchased died within about a year, the Corsair has been a great fan and worked well (at least until now).
So as I sit here I see a few possible issues:
1) Motherboard firmware maybe requires updating to provide the correct on-board power for the 8800GTX?
2) Motherboard will not support the 8800GTX, requiring an upgrade.
3) The Power Supply, though mentioned as having run 8800GTX's in SLI mode at computer shows online (don't have links at hand, sorry), isn't providing enough power. I'm currently using the 2 included 6-pin video card connectors to go straight from PS to Video Card. (Maybe I need to use the molex adapters and see if those work better?) If the PS is the issue, then obviously I'll upgrade.
Any thoughts or suggestions would be appreciated. I have other PC's, but this upgrade is my primary and I use it daily. The faster it's running full speed, the better.
Thanks!!!
Thanks!!!
