purplepencil
- Sep 10, 2005
I was wondering if it would be possible to mount a rad to the top of the case by simply drilling holes in the top and threading through either long screws or spacers. This would allow the rad to access fresh air, and remove a heat source from within the case. Has anybody seen this done? I'd like to know what thoughts you have.
The reason for doing this is that I need to upgrade my passive water cooling solution and I don't have any tools whatsoever, and am on a limited budget, this option would only require buying a cheap electric drill for the holes.
Thoughts?
Dave
Thoughts?
Dave
