I put mine into push-pull with all sorts of different fan combinations and it never made a difference.
Except increased noise...
Yeah. Might get a small improvement in airflow but that comes at a price of increased noise. What's the difference between 2 fans versus 1 anyway...about 3-5C at most.
When you are pushing your oc to the limits, 3-5C is the difference between stability and bsod.
I seriously doubt it...your overclock should not depend on a few degrees. If you overclock properly and keep the system 100% stable, it should still be well under the CPU's limit at both idle and load.
