milling_hordesman
- Jul 26, 2004
I've got a quick question regarding power supply quality and life expectancy, the new 24-pin motherboard connectors, and some other general paranoia that has no proper title.
I've managed to burn through 2 power supplies in the past 6 days, each dying after a 3-day usage period.
The first power supply was called a "Power Magic by XCase." It sounded shady to me, but it was 600W and it did come titanium plated, and it was only $35, so I said "what the heck" and tried it it my new system:
AA8-DuraMax mobo
Prescott 3.40 GHz LGA775
PCX 5900
1 gig Crucial DDR2 memory
2 HDD, 1 CD-RW, 1 FDD
5x 80mm standard LED fans (not like tornados or something)
After 3 days of periodic (not continual) use, the computer suddenly stopped in the middle of a Need For Speed: Underground race with a sudden *beep* of alarm. From that moment forward, when I pressed the power button, it paused for a bit, then issued a *beeeeeeeeeeeeeeep*-*beep*, the paused again, etc.
So after making sure everything was fit properly and nothing had been damaged, I tried replacing the power supply with my old workhorse, a 400W generic but fairly quality power supply, on which I still can't find a brand name. The initial problem was that the fans were drawing too much current on boot for it (they take a lot of juice to get going, as i learned in phys 121), so I disconnected them and ran the case open with a desk fan blowing on it instead.
After 3 days of this usage, in which I only had 1 case fan running at about 1200 rpm (basically almost idling), this power supply died in a very similar fashion to the 600W one, which I have already RMA'd for a refund.
I'm thinking that it's the motherboard connector that's dying, or whatever powers the motherboard connector, since it seems to be *beep*ing when it tries to verify motherboard component voltages.
My questions are this:
- Even though the 24-pin connectors are backwards-compatable with the 20-pin cables, is it drawing too much current through the 20-pin cable and burning the thing out? I mean, I haven't really seen any 24-pin PSU's out there to get, anyways, but is that the problem?
- Or is this a regular occurence when a PSU is overloaded, and should I just get a more notable brand PSU and not worry about it?
AA8-DuraMax mobo
PCX 5900
