black_b[ ]x
- Jul 1, 2002
Having some issues lately, first thought it was the motherboard, but now it doesn't start up at all. It ran a few times and just shut down after 10 min, no loud pops or anything. Now it doesn't even turn on so I'm assuming the PSU is dead (tried to short the green/black wires on mobo connector to start it too). I guess need a new one, but this is for a 3 year old rig, so I don't want to spend a lot.
A64 3200+ (754)
2x 512MB Ballistix
MSI K8N Neo Platinum
eVGA 6800 ultra (needs 2 molex)
Danger den water pump for CPU and GPU (the older D4 model)
74GB raptor (again, 3 yrs old)
12x DVD
4x 120mm fans
The dead PSU is a 550W Fortron. I could put the stock air cooling gear back on this thing to take out the load of the water pump. or maybe if i rearranged my case i could fit in 2 PSU's and use the 300w from my previous build just for that and the fans (I'd have to support a few more older ATA HD's then).
my other option is to just plan for my upcoming build and buy for that, that way if the PSU doesn't fix things, I don't have to return anything. Probably a quad core build with an 8800GT something, possibly re-using my WC setup.
A64 3200+ (754)
2x 512MB Ballistix
12x DVD
4x 120mm fans
