Damar
- Jun 20, 2004
I'm going to be putting together a machine for a friend.
He had a power supply from his old machine he wanted to use, and said it should be adequate for the new build, but I'm kinda leery, and not a power expert, so though I would post here and get some opinions.
The power supply he wanted to use is a Thermaltake 550W. It's not the Toughpower line though. I don't have it in hand yet to examine it, but the 550W is correct.
The new machine that needs to be powered will be.....
Intel Core2Duo E6850 (Dual 3.0Ghz)
2 GB Crucial Memory
2 x 7800 GTX Video cards in SLI
4 Hard drives (various sizes and interfaces)
DVD-Burner
5 x 120mm Case fans with LED's
I guess its the two 7800 GTX's and the CPU that concern me the most, but maybe I'm wrong. Personally I usually go way over on the power supply when I build a box so it will last through several upgrades and not be running at full load all the time.
Opinions??
2 GB Crucial Memory
DVD-Burner
Opinions??
