I bought a cheap Bronze PBg3 with no battery to play with have the yo/yo plug though. The problem is when I shut it down the only thing it remembers is the name of the user not the setting any thing that I changed or put in or on it.
The question is, Is this the (BIOS) I know it is not called that on mac but anywho, battery or wtf is going on. I dont get it.
Can you help?
Thanks for your time,
Scott
Can you help?
Scott
