ChingChang
- Mar 27, 2003
I haven't been following this type of hardware really, just need help choosing parts for a powerful workstation/server. Price does not matter, only thing that matters is performance and reliability.
I really need some good responses ASAP... this is for an assignment.
CPU:
I'm thinking quad dual-core Opterons would be good..
http://www.newegg.com/Product/Product.asp?Item=N82E16819103004
Motherboard:
This look ok? Got PCIe slot for video card, and some PCI-X slots for drive controller?
RAM:
I'm thinking filling up each slot in the motherboard with 2gb ECC registered.
(unless it shouldn't be running XP Pro x64... there many issues with media development programs?)
Video:
nvidia Quadro FX? or ATI FireGL??
not sure which one is better...
Hard Drives:
68pin SCSI the way to go? Which is the best controller?(keep in mind I have 0 experience with SCSI... need some good advice here)
I'm thinking two drives in RAID 0. But is it possible to get 0+1 with SCSI? Or how should the data be backed up (yes I know RAID is not a backup.)
Power Supply:
Not sure really... does PC Power & Cooling make good server type PSUs? If not, which is the best one I can get? (guessing it should be redundant too)
Case:
Anything that will support the Tyan motherboard I have selected.
(form factor says SSI MEB v3.5 footprint.. I have not ever heard of that )
Monitor:
if you could spend as much money as you wanted, what would you get?
Speakers:
Is there a sound card that can work with the tyan motherboard? PCI-X???
(might need a different motherboard if not...)
And just need quality speakers, nothing to crazy.
edit: I have just been informed that PCI cards work in PCI-X slots
CPU:
Motherboard:
RAM:
Video:
Hard Drives:
Power Supply:
Case:
Monitor:
Speakers:
