As I Lay Dying
- Aug 8, 2005
Ok, so I posted earlier about a power mac g4 psu, so the psu unit is fine tested it with the power using the paper clip trick. so I plug everything in and the machine turns on by it self, so I am like great this thing works, no hard drive but it works.
so I hit the power button, nothing, so I say press it again, this time I hold it down, nothing, the reboot button works great though.so now I am a little puzzled. So I yank the cable out the back, and its off, grab a live linux ppc disc just to see if everything will work. so I plug the cable back in and nothing.... does wanna turn on. So It seems like the power button this thing is gone, which seems as the button seems to work fine mechanically.....checked the power connections. any suggestions what might be the culprit here...
