Ok so this is what is taking place my loop consists of the following in the order listed:
pump, rad1, cpu, north bridge, rad2, gpu, south bridge, rez
What is happening is a pressure decrease across the system as a whole. There are no leaks in the system and it is resulting in lackluster performance.
Now, there are two ideas i am bouncing around to fix this. the first one being:
add a second pump off of the rez, and use a Y connector to connect both of the pumps at X location in the loop so that the loop has the combined pressure of two pumps working on it.
The second idea i have is to add the second pump in between the north bridge and the 2nd radiator so that the pressure is constant through the lines.
I think both have good potential to fix my problem i just need some thoughts.
As for the system since i know someone will ask
Q6600 lapped (DTek is lapped as well)
8800gtx
P35-T2R
Let me know what you think. i know for sure tonight i am going to try and shorten my hoses as much as possible. since i can imagine that this would cause an issue as well.
8800gtx
P35-T2R
