I just built a C2D system and went through the normal setup, I have XP and Vista setup and all seems to be OK so far besides the temps. I have a E6400 paired with an AC Freezer 7 Pro and an EVGA 680i SLi AR mobo. Big problem here is that at stock speeds and voltages hover at 42C-44C idle and 48C-50C idle @ 3.0 GHz and 1.375 vcore. Under load the temps are at 65C-70C @ stock and about 75C-80C at load sometimes peaking at 85C @ 3.0 GHz and 1.375 vcore. I have one of the newer L2 revisions of the E6400 which seems to be stable at 3.0 GHz and 1.375 vcore.
Core Temp is pulling the temp readings and the weird thing is that in core temp and cpuz, the vcore is off on both. CPUZ shows the voltage at 1.213 and core temp shows 1.325. I have the entire system powered by a PC P&C 610 silencer so I would doubt the voltage being supplied was fluctuating hardly any if at all.
I've flashed to the latest P25 BIOS for the 680i and have all the latest drivers installed. I'm using AS5 silver, reseated the HSF just to make sure that I didn't do it wrong the first time. I made sure both the CPU and HSF was cleaned properly and made sure not too use too much AS5 both times. I checked the IHS on the CPU and it didn't look like it was concave at all.
I don't think the problem could be airflow either, I have an P180B case with the two stock exhaust fans on the rear and top at high when on load and then a Yate Loon D12SL-12 intake in front of the HD's in the front of the case, and another D12SL-12 in the bottom of the case blowing on the PSU. All the cables are either tucked away as best I could get them or behind the mobo.
I've done everything short of lapping and cannot figure out what else it could be causing these temps to be so high. I'm about to start blaming it on the stepping if the lapping doesn't help much, and I know the cooler isn't the best in the world but the CPU should be running cooler then what it's at right now. Anybody have and suggestions as to what else I can try to see if I can get these temps down a bit?
Under Load
Peak
Under Load
Peak
