Hi, I haven't been able to play iso's of blu ray disks through vista media center using pdvd 8. It starts up then gives the file format error. I can however open and play the iso using windvd just fine. I used anydvd to rip the disk to image and have anydvd running in background. Was/is there something I should do to make playback happen?
So-- Vista 64, Powerdvd 8, Windvd, Anydvd hd, Blu Ray ISO. Won't play using vmc mymovies "watch" or using powerdvd as the default open with program. Same iso will play using windvd as "open with" program, and will play using pwrdvd when br is in drive.
I normally will just use what works but I prefer the gui of mymovies in vmc
Thanks!
Thanks!
