thefordmccord
- Jun 20, 2001
OK, I have an interesting problem and I just wanted to know if anyone else has had this problem. I have a 6600GT and I just updated to the latest Nvidia driver. Now when I try to do anything that uses the Java Runtime Environment, my computer completely hard locks. I have to hold the power button it to turn it off. If I disable my secondary monitor in the driver, I have no problems at all. I was using the 78.01 driver and had no problems at all. I have used Driver Cleaner to remove the driver and reinstall, but no luck. I have also tried reinstalling JRE, but that didn't help either. I am about to run driver cleaner again and go back to my old driver. Just wanted to know if anyone has had this problem and if they have, do they know of a fix?
BTW, the rest of the system is in my sig.
Thanks!!
Thanks!!
