Scorpionjwp
- Jul 14, 2004
Ok I have a update, I have the hinge installed and lid installed. The lid however has a lip on the front side and is offset from the rest of the case. I did this because it makes it easy to open the top by doing so, I'll find some way now to get the top to line up with the offset.
Oh by the way, the Crypt keeper called me and he wants his coffin back.
Here is where I started cleaning up the inside of the second floor in the case. And making it more of a desk, will install shelf pins later after I finish mounting the walls to support the shelf. Or I'll make a inlay for the inside that is mounted for a smooth suface, I don't know what I'll do yet at this point other than finish the top.
Here is the lid in it's plain glory
Here is a better view of the large size of this lid, now to measure up for the mount for the 32in HDTV Aquos.
More updates as they come....
