Some internal "modding" for my full tower Xaser III V2000a. Check the pics below if you dont follow
To do:
1. Sleeve all cables in red and replace IDE cables w/round red IDE cables.
2. Changeover all plugs on PSU and fans to red.
3. Add red CCFLs.
4. Remove 1 side-panel fan and surrounding mount area.
My questions
1. Should I go for UV lighting? I like the idea, but will UV parts be a good red when the UV lights are off? What about 1 regular CCFL and 1 UV CCFL? Could I run them off the same inverter?
2. Will removing the top fan on the side panel really degrade performance? BTW, I flipped it over a few minutes ago (its blowing out now), my case temp dropped from 33C to 28C.
3. I looked for a few minutes at PSU sleeving kits, I only saw 20-pin MOBO connecters. Do they have kits and/or separate 24-pin MOBO connecters?
To do:
3. Add red CCFLs.
My questions
