weasel2htm
- Sep 8, 2004
I've decided that my dual PII 266 server is to big and two hot for my light file serving needs, so I decided to build my self a smaller server.
Using a case intercepted from the trash at work
Case Pic 1
Case Pic 2
A motherboard given to me by a friend, a Gigabyte MOBO, pulled from a Compaq and flashed with the generic Gigabyte BIOS (He said that I exorcised it) With a K6/2 450 CPU.
MOBO (Yucky pic)
Also used, two 32 Meg sticks of PC66 (I know the K6/2 runs at 100 but this will get the unit running, will probably cull memory out of my dually when I take it out of service.
4.3 Gig Seagate HD for O/S
and a 3.5 floppy drive. All pulled from an Acer Aspire (Assfire) system given to me with a bad (and propriatry) Power supply.
8X CD-ROM from Junk Pile, (Will use a faster unit for the initial O/S Load) as most CD file transfers wil take place via network.
Intel Pro 100 Nic from junk Pile.
Plan of attack:
Put above componets into system (already done but still have to install IDE and floppy cables)
scrounge Power Supply
Load O/S, planned to be Win 2000 Pro as it wil serve my modest needs and the Systemax case as a licence sticker on the back, it should also run faster than if I installed the server flavor.
Will also pull 40GB Storage Drive out of my current server for, well storage
Will have more pics later, left my good 5mp camera at work and had to use my old junky one.
I'd like to place this unit out in the garage but becasue the garage has No A/C I'm a little worred about heat. It will *Probably* be OK but I won't stick it out there (rarely gets much above 90F out there) without being loaded with case fans and the [H] opinion.
Case Pic 1
Case Pic 2
MOBO (Yucky pic)
Plan of attack:
