kidicarus74
- Feb 23, 2004
hi all... i've been around the modding scene for years now, and i've done a little work with using my computer on a tv and hooking it up to my stereo but i can honestly say outside of that, i know nothing about HTPC's.
i already have a really good home theater:
sony 5.1 600w receiver,
sony progressive scan 5 disc dvd changer,
2 1800w self powered DefTech floorstanding speakers w/ built in 250w subs
1 1000w self powered DefTech center channel w/ sub
2 deftech 200w pro-monitors for the surround speakers
sony 27" wega tv
tivo
modded xbox
i want to add a projector to it (and eventually a dedicated htpc) but don't know at all what to get. It will be set up in a room that can be almost dark to pitch black all the time. All I really do is watch movies so i kind of want a 16:9. And mostly it can't be ungodly expensive (under $1200 if at all possible). It needs to be high def capable, with component (rgb) inputs and a dvi input at the least.... so really i'm just looking for advice and suggestions. what brands are good? what lumens do i need? can 4:3 do 16:9 ok? how big can the picture be based on how far away from the screen the projector is?
thanks in advance
sony 27" wega tv
tivo
modded xbox
thanks in advance
