Hi everybody,
A friend of mine is building a new PC, and he's leaning towards a microATX / Aria combination. Other than the cube-ish case, his only other requirements are that the motherboard have a PCI-Express x16 slot, for future expandability, and that it should be very quiet (while keeping the important parts cool enough). That said:
What are his options? If you own an Aria, what's worked for you?
- Should he go with Intel or AMD? It seems like AMD is slightly better in the temperature department these days, especially with Cool'n'Quiet, but I'm not aware of any microATX motherboards with PCIE for Athlon 64s that support the feature.
- My friend seems to believe that watercooling of both the CPU and the videocard (with the associated extensive modding of the case to fit the radiator, pump, and extra fans inside) will be necessary to meet his noise and temperature requirements. Is air cooling a possibility?
