will be using the component out for the HDTV.CrimandEvil said:Just so you know ATI's drivers for DVI out to an HDTV are considered "decent" at best, they're pretty basic and if you have any problems its frustrating to get it working 100% correctly since they don't really have any sort of tweaking options. Add to that the noise level of the stock cooler and how much heat they generate doesn't exactly make them the most HTPC friendly cards.
Currently if you're going DVI out then you should pickup an NV card, the 7600 GS makes for a very nice card.
Flight Sim 10 is just around the cornerLord Nassirbannipal said:Is there some reason you need 2 gigs of RAM, a dual core processor, an X1800, and a $279 case for an HTPC?
