DarkScythe
- Mar 7, 2008
Hello,
I've been waiting for a while in hopes of getting a nice display soon, but it seems the trend is toward the wide-gamut monstrosity.
When I first saw the HP 2475 I thought it was going to be great - 24", affordable IPS and tons of input options. However, when it was released, we found out it was wide-gamut.
I don't want to deal with the wide gamut headache, as I do mostly web work, so sRGB makes my life less complicated. It seems my only options is a NEC 2490, and has been for a while. When I heard the NEC2490v2 was announced, I hoped they would update the inputs too, but unfortunately it retains the same meager set of inputs.
Since then of course, many places have started listing the 2490 as discontinued, and as it has the A-TW, I might have to jump on it soon before they disappear altogether. Granted, I'm still using my Samsung 172x 17" TN which doesn't have an A-TW polarizer, so I'm not sure how bad I'd feel about not having one if I were to go with the 2490v2 instead.
In any case, this is going to be my all-around general-purpose monitor for everything I throw at it/my pc. This includes FPS/RPG/RTS gaming, web work, movie/anime watching, photo work, video work, and general office work. Along the lines of gaming, I also want to plug in my PS2 (or eventually any other console) using component to play without hogging up the TV, but the NEC does not have component.
Is console gaming on the NECs even possible? If so, how do I go about it? I do want good image quality, considering the price of the monitor, but I'm not going to go nuts and spend $500 on gear to hook up my PS2 either. I'm not sure what I need though. Is a simple component > RGB adapter enough, or is there some converter box that's required? If so, which ones are good?
Also, I recall something about games displaying different modes (progressive and interlaced) but I'm not sure how this will impact the gear that I need. I heard some boxes do not do very well with one or the other. I'm not sure what modes my games have, but I have a bunch of North American PS2 games, as well as a bunch of Japanese imports that I play semi-often.
Any ideas?
Thanks in advance for any advice.
Any ideas?
