RyanLucier
- Nov 23, 2006
Ok I've got a Swiftech MCP350, and it's worked great for over a year now. However, I left today for about an hour and a half and when I came back, my computer was off. I turned it on wondering why it shut itself off, it began running but crashed entering windows then turned itself off. This repeated 3 times. At this point, I popped the side of the case off and realized that no water was flowing. My pump had a bunch of air sitting at the intake/exhaust tubes. I am assuming what happened was the system auto shut off when it hit 60C on the cpu, as I've got this set in the bios, so I don't believe any damage has been done.
I was able to get the pump running again by turning the computer on while holding one of the water tubes above the pump to get water running into it again.. and now the system works fine.. but the question is... do I trust it?
I'm told running a magnetic pump that isn't primed can ruin it immediately. Mind you I originally primed this pump properly before ever turning it on, it was setup correctly (also the reservoir is the highest point in the system and such, I've setup watercooling setups before and am relatively familiar), but clearly for whatever reason it stopped running today and I turned the system on 3 times without knowing no water was flowing (and there was a lot of air bubbles around the intake/exhaust of the pump).
So guru's.. anyone have any opinions? Is it simply a matter of time before it fails? Or should I just keep an eye on it and if nothing happens, ignore it and be merry
