UrielDagda
- Nov 16, 2004
I recently purchased the nVidia Purevideo codec, after having an un-removable expired version of NVDVD for ages that would just crash when I tried to run it. Now with the purchase and activation of the Purevideo, NVDVD works again. Is it using the Purevideo codecs or old NVDVD ones, or am I just not understanding what NVDVD is?
When I play DVDs on Media Player and nStantMedia they look like crap. It has some super-brightness effect that cannot be removed using the Purevideo controls, because even with a background that looks like a horribly bleeding LCD backlight (I am using a CRT), the darker areas are still too dark to display, and the bright areas are just bright blobs. However when I use NVDVD, it displays fine without that problem, but I am not sure if its actually taking advantage of the codec I paid for.
Also, is it my imagination or is the nStantMedia player an obtuse piece of shit? Why did they replace the NVDVD player with that?
System Specs:
Athlon XP 3200+
BFG GeForce 6800 GT OC
1GB Corsair memory
Sony 16x DVD drive
Forceware v78.01 drivers
24" widescreen HP A7127A monitor running @ 2048x1280
System Specs:
Athlon XP 3200+
1GB Corsair memory
Sony 16x DVD drive
