Scotty_SFF
- Jun 2, 2006
So i finally got my system up and running. Specs in Sig.
At the moment i have it at 3.33GHz w/ 1.4v, seems to drop quite a bit when under load, so it goes to about 1.35. That helped with stability at lower speeds.
Im trying to stress test with 2 Orthos' running, one or cores 0&1 and the other on 2&3. But it stops in just a few seconds, temps under load at 3.2ish i think it was were around 60*C on the highest down to about 54*C
Should i up the voltage, if so how much? I've read they can take 1.5 according to Intel but i don't want to ruin it. This is my first major overclock, only upped PCs by a few MHz before.
I have disabled Speedstep, C1E and other stuff i have read about on XS and other OCing guides.
