This isn't even how it works, cores don't get RAM, applications get RAM. Each executable should be able to use both cores (although, for now, many will only use one) regardless, RAM is something completely separate from cpu. Each process will use the RAM it needs, just like in single core applications.
Now, please tell me you're not one of those poor people that don't realize that XP can't handle 4GB of RAM.
ur thinking of 8 gb not 4Now, please tell me you're not one of those poor people that don't realize that XP can't handle 4GB of RAM.
XP 32-bit can't address more than 4GB of RAM.
qft. Just in case that point needed more support.
Yikes guys. Ok, when I said "XP can't handle 4GB of RAM" I meant, it cannot address a whole 4GB of RAM.
Also, I'm quite certain that "poweraid" was not referring to MB of cache per die considering he said he "was gonna get 4 gb ram, but 2GB per die isnt very appealing to me..." Perhaps he needs to just ask what to get and listen to our advice, or do a LOT more research before asking questions.
