fibroptikl
- Mar 9, 2000
I work in storage and as a result I'm often switch cables between my lab computers to different DAS/NAS/SAN RAID devices. Sometimes I don't do anything, other times I might move the cable 50 times a day between them.
I got some nice cables - with a metal connector and a long pin (so it's easy to find and push down) - but I can't find where I got them from. I have some cheaper ones but the little plastic pin on the RJ45 connector is so short I can't barely reach it.
So my question is where can I find some nice cables with metal RJ45 connectors (so they don't break off - but if you know of some good plastic ones, that's fine), and long plastic pins on the RJ45 connectors. If there is a cover I'll probably cut it off but if it doesn't have them that's fine.
Any advice/links are appreciated.
