I recently changed from a noisy Thermaltake Volcano 11+ CPU Cooler to a ThermalTake Silent Boost CPU Cooler for my AMD Athlon XP 2800+ Barton. I've got an Asus A7N8X Deluxe Rev. 1006 Motherboard and 1.5 GB Corsair XMS PC2700 DDR RAM, Windows XP Pro SP 2. I just upgraded my BIOS to v1008. Running 6 80mm fans in my Lian Li PC75b Case (2 exhaust, 2 intake) and a 430 watt Enermax PSU (2 fans). Gainward Geforce FX 5950 256 MB Video Card.
Before I put the new cooler on, i cleaned off the processor with some special alcohol my father had for cleaning off the thermal grease. I then added a thin layer of thermal grease (Arctic Silver 3) to the die and spread it a little bit with a flat blade razor. I did notice that at first, the tube of thermal grease was a bit liquidy, but became a little bit more solid when I shook it up (this might be my issue right there?). At any rate, I got it on the motherboard, and fired up the PC and it was running fine temps, around the same idle temps as before - 41-43 degrees Celsius. Load temps of 45-46 C.
I decided to test out some games, mainly Far Cry, Doom 3 and Star Wars Galaxies. It was with Far Cry I got a weird error that I didn't get in any other game. Something within my PC would constantly beep (long beep) until I either /quit or alt-tabbed out of the game. Now I'm not really sure if it's the CPU, motherboard or Video Card - but what worried me is my CPU is now reading 50-55 degrees Celsius (In Asus Probe). In the Bios it says 63 degrees Celsius after I rebooted.
I know the max recommended temperatures is 85 degrees Celsius for this CPU, but I much prefer to see it down near 39-41 degrees Celsius. Could my heatsink not be seated well upon the CPU die? Would this be why I'm getting temperatures 10 degrees higher than before? Might I have to redo the thermal paste? I've got a good amount of case fans, so I would think that there would be no issues with case cooling. I have noticed in the past dozen hours since I first noticed the issue that the temps have fluctuated up and down from 50 to 45 to 50. Maybe I just need to let it burn in?
Anyways, I'm kinda a stickler for the CPU temps. They used to idle at 41-43 and at max load were only as high as 48-49 C according to Asus Probe. Any thoughts or help anybody could give me? Many thanks!
