Yeah but will you still be able to play it if you don't have the CD? Assuming original owner never uninstalled it.WhyYouLoveMe said:If the CD-key has been registered to another user I don't think it affects anything besides e-mails containing useless information. As long as the game isn't installed on more than 1 PC you'll be fine.
No I meant that if the original owner sold the CD to me, why would he not uninstall it from his machine.WhyYouLoveMe said:Umm... how are you going to install it without the CD? You need the CD to play the game unless there are illegal hacks out there. (which we shall not discuss) Are you buying just the CD key?
I'm confused.
Not true, I know I create a mini image with Alcohol 120% in the event my niece or nephew decides to play frisbee with the CD.WhyYouLoveMe said:Umm... how are you going to install it without the CD? You need the CD to play the game unless there are illegal hacks out there. (which we shall not discuss) Are you buying just the CD key?
I'm confused.
Major_A said:Not true, I know I create a mini image with Alcohol 120% in the event my niece or nephew decides to play frisbee with the CD.
I was actually commenting that maybe the guy/gal still has it installed on their computer.WhyYouLoveMe said:So how are you going to create the image without the CD? lol
That's what I was getting at. I thought he meant he was buying just the key, installing the game and then, for some reason, losing the CD.
