hi again, got a question about the revision number of my Asus A7V8X. using cpu-z, I get the following:
I have updated the bios to version 1011. Can u upgrade the mobo revision number? I checked on amd's site to see if the 2400+ XP cpu can be supported on my mob and this is what it told me:
A7V8X
revision: 2.01
ATX VIA KT400
AGP
DDR
Award 1012.005 03/21/2003
so it says it needs revision 2.01. How do u get that? Also I will have to update the bios to 1012 but that is easy to do. Thanks for any help
A7V8X
revision: 2.01
ATX VIA KT400
AGP
DDR
