the_transporter
- Aug 19, 2004
I already bought the S1, but I need to buy some sinks for the VRMs. I'm planning to buy a set of EnzoTech BCC9 low profile copper sinks: http://www.enzotechnology.com/bcc9.htm
So basically, I will have 16 sinks in total (8 aluminum from the S1 and 8 copper from the EnzoTech). My question is, which combination should I use?
1. Use all 8 EnzoTech copper sinks on the memory and use 4 S1 aluminum sinks on the VRMs.
2. Use all 8 S1 aluminum sinks on the memory and use 4 EnzoTech copper sinks on the VRMs.
I'm thinking 1, but I am not sure to be honest. Which would be hotter during load? The VRMs or the memory? I will use copper on the hotter ones
Thanks.
Thanks.
