KillerPotato
- May 14, 2005
Are you all using 24 pin PSU connectors to your motherboard? I'm in need of an upgrade, and because the pci-e X800XL was quite a bit cheaper than the pci-e 6800GT, I've been leaning in ATI's direction. However, the X800XL seems to draw all of its power from the pci-e slot, and I hear that the extra 4 pins for the new PSU-Mobo connectors are almost solely for powering the PSU, but you can still run a 20 pin PSU on a 24 pin motherboard.
I'm currently using a 480W Thermaltake PSU that I bought a couple months ago after an old one failed, and dont want to have to buy a new one if mine will work reasonably well. Is anyone running an X800XL using only 20 of 24 power pins on their mobo, and can tell me about its stability? Has it caused any problems to people who use this setup? Otherwise I would probably have to go for the X800 pro, hoping that the external power connector it has could make up for the lack of the extra motherboard pins (would this help in the first place?). Thanks for any help.
(Sorry; I know I posted this in another part of the forums. Trying to get as much advice as possible before I buy parts)
