seniorpaul
- Aug 8, 2005
I"ve got a couple of quick questions regarding shrouds, as i'm working on an external watercooling setup. It's my understanding that a shroud is used to basically put a little bit of distance between your fan and rad to improve airflow when your using a push configuration. How much space is needed? I'm planing on using Yate Loon 120mm fans and a Thermochill PA120.3.
Also, is there any benefit to adding a shroud when your using a Pull config? If so, how much space is needed in this situation?
