Hello,
Need some help here.
I'm looking to get the stock amd x2 heatpipe HSF to replace my Arctic Silencer 64 Ultra.
I'm wondering what option do I have for to replace the fan on the stock amd heatpipe?
I hear the stock fan (Delta brand; 80mm; 44cfm @ max rpm) get pretty loud.
Should I get an 80mm replacement with a similar cfm rating? What 80mm low noise fan options are out there with similar flow rate?
Or should I get an 92mm fan with similar cfm rating and add an 80mm to 92mm adapter? I hear that the efficiency of using an adapter is not good, is this true?
Thanks,
Thanks,
